Hi there, please try the suggestions below to see if it works:
1. Restart the aircraft and see if the error recurs. If it does not appear again, you can use it normally
2. Check the centrifugal motor to see if it is stuck (foreign matter is stuck, the spinner plate is worn, etc.). If so, please clean or replace it in time;
3. Replace the centrifugal motor;
4. Replace the ESC cable. |
