P3 app "IOC"
1520 8 2015-9-8
JohnCom
Flight distance : 292526 ft
Why will it the IOC turn on in my P3 App.--------------------------------------
2015-9-8
Cetaman
Flight distance : 2528264 ft
Aloha JohnCom,
     You need to download the new DJI Go app.
Aloha and Drone On!
2015-10-2
pm07
Flight distance : 13104 ft
South Africa
I downloaded the new app for my iPhone and it still greyed out.
2015-11-19
Cetaman
pm07 Posted at 2015-11-18 22:56
Aloha pm,
     The IOC slider is linked to the "Multiple Flight Options" slider.  It is grayed out because it is under the control of the slider above it.
Aloha and Drone On!
2015-11-30
pm07
South Africa
Cetaman Posted at 2015-12-1 08:56
Aloha pm,
     The IOC slider is linked to the "Multiple Flight Options" slider.  It is grayed ou ...
still greyed out Cetaman
2016-2-8
Cetaman
pm07 Posted at 2016-2-8 04:17
Aloha pm,
     Is the "Multiple Flight Options" grayed out or just the IOC slider below it?  The IOC slider will always be grayed out.  But if the Multiple Flight Options slider is enabled, then you will be able to use the five IOC options the way I described above.  If the Multiple Flight Options slider is grayed out, then you have a problem.
Aloha and Drone On!
2016-2-8
lesio2807.o2
Poland
So, now after this update, all users cant slide "enable IOC" , yes?? This will be turn on , automaticly, when you change to F-mode???
2016-2-9
Cetaman
lesio2807.o2 Posted at 2016-2-9 07:03
So, now after this update, all users cant slide "enable IOC" , yes?? This will be turn on , automati ...
Aloha lesio,
     Actually, the grayed out slider has nothing to do with this update.  Months ago after the first update for IOC, the second update (I think) started graying out the IOC slider.
     You are right though about the "F" mode switch.  No matter where the "Enable Multiple Flight Modes" slider is in the settings, if your bird is up 10 meters or more and out 5 meters or more, and you switch to "F" mode, you will be asked if you want to enable multiple flight modes.  Confirm it and you should be able to use the 5 IOC options.
Aloha and Drone On!
2016-2-9
lesio2807.o2
Poland
Thanks Cateman!!
Aloha and cheers
2016-2-10
