DJI Wanda
Hello, there. We checked your video and your questions.
In the video, your operation exceeds the controllable range of the Roll axis. If you want to tilt the roll axis to the left or right, we recommend you tilt it within ±30°. If the Roll axis and Pan axis almost overlap, then the gimbal will change from three-axis stabilization to two-axis stabilization, which loses one axis and thus will cause some abnormal vibrations or shakings.
For this operation, we recommend you lean your body to tilt the gimbal instead of just moving the handle.
