5 GPS satellites at the most - only atti possible
579 0 2024-1-4
rogiervdheide
Portugal
NO GPS FIX can you help me, please?
Fellow M600Pro pilots and DJI support team, happy new year!!
One of my Matrice 600 Pros does not acquire satellites. At the most, I get 5 satellites. I have tried:
  • in open field
  • placing the drone 2 meters above the ground
  • flying in atti mode higher up, let´s say 15 meters above the ground
  • waiting long (30 minutes)
None of the above results in more satellites. All systems are normal:
  • IMUs calibrated and normal
  • Compass calibrated and normal
  • M600Pro firmware V1.00.01.67
  • Lightbridge 2 Air unit firmware V1.1.81
  • Ground Controller firmware V1.2.52
  • The GPS analyzer app on my iPhone SE shows 12 or more satellites
No matter which MC/IMU1/IMU2 I prioritize or use in the DJI Go app, I do not get a GPS fix beyond 5 satellites.
What is not normal: DJI Assistant shows GPS1 and GPS3 as normal. However it shows GPS2 during 3 seconds normal then 2 seconds greyed out and this is continuous. However with the other two GPS antennas the drone should still get a GPS fix.
So I do get 4 or 5 satellites... Just never 6 or more so I can only fly my Matrice 600 Pro in atti mode.
Do you have any clue?
Thanks in advance!!
2024-1-4
