Tusharfromearth
India
I have probably found the best low light settings,
but take a deep breath, this post/reply is gonna be long.
I primarily use only 2 settings that i have saved in profile mapped to C1 and C2 settings, and these are as follows :
Also btw thanks to suphot above in this forum, this answer includes his settings too.
FOR LOW LIGHT :
1. Do note that due to fixed shutter speed of 1/100(or 1/120 for 60Hz current countries), the very bright sky will get blown away so its not suitable during daytime, rest everything is fine).
2. Will not work great on motovlogging/fast paced movements like quick camera panning or running, but walking and moderate speed panning would be fine.
3. Btw action cameras are not known for great low light performance, but i've head buying gimbal does increase the performance of camera greatly in low light, also if Vlogging, buy a different cage which has multiple cold shoe mounts, and then mount a LED light like Ulanzi VL49 on it. This way your face is lit nicely even in low/evening night while Vlogging.
So coming to settings :
Pro mode/settings enabled
FPS = 30 (keep it on 30Fps only, irrespective of fact you live in 50Hz current country, cuz shutter speed of 1/100 will fix the flickering) Dont make it 25 fps , cuz, except for when camera is stationery in 1 position, it looks too jittery when camera is moving.
Exposure (auto) - but still some settings need to be set even on Auto mode --> EV = +1.0(click on top left of screen to change this), Shutter speed = 1/100(or 1/120 for countries with 60Hz electricity), ISO = 100-12800
WB = auto
Color = Normal (Dlog-m wont work cuz we having low light enhancement setting ON, which will automatically convert it to 8-bit footage, and disable Dlog-m).
FOV = Narrow(or you can put wide as well if you want, but idk why i liked narrow one more as its zoomed in and this camera already feels very wide as compared to smartphone cameras).
Image adjustment = Default
Stabilization = RS (Do not put it on RS+ as that produces softer and little bit more shaky footage - and no, adding sharpness in post production/inbuilt camera settings wont fix that).
Low light enhancement : On (Kindly note color will become 8 bit instead of 10bit, but thats fine 8 bit still has lots of color)
FOR DAYTIME/Good lighting conditions : (This would be suitable for almost any condition when light is good)
Pro mode/settings enabled.
FPS = 50 (make it 60Fps if you live in 60Hz current country)
Exposure(auto) - but still some settings have to be changed, EV = +1.0, ISO = 100-12800, shutter speed will be set automatically, cuz we chose auto settings.
WB = Auto
Color = Normal 10bit (or you can use D-log also this time if you have patience to Color grade it later on, cuz i've heard Dlog will give greater dynamic range after color grading is done)
FOV = Narrow
Stabilization = RS (Do not put it on RS+ as that produces softer and little bit more shaky footage (and no adding sharpness in post production/inbuilt camera settings wont fix that).
Low light enhancement : Off (it works only till 30fps)
P.S. : i have an external mic (comica vm10 pro) which i connect using usb-c cable - and best settings there that i found are mic gain(on the mic) set to max, and inbuilt camera gain set to 0. |
