Output flight videos to TV
1861 3 2024-1-6
Dingaling
Flight distance : 15807 ft
I have the Mini3 drone and RC controller (with the screen).
The user manual says the USB-c port on the bottom is for charging and output.
But I can't get any HDMI output at all.
I've seen mention that you need the RC Pro controller.
All I'm looking for is the simplest way to review recorded flights on my TV when I get home. I'd prefer not to be popping the micro-SD card out every time.
Also, I added 128GB card to the RC, but not all drone card videos are making it there...what do I need to ensure for that to happen.
2024-1-6
DJI Tony
Hi. It is not possible to use an HDMI cable to connect the DJI RC to a third-party display for screen mirroring. There is no HDMI output port on DJI RC, so DJI RC doesn't support the HDMI output. Regarding the missing videos, the SD card should be inserted in the drone instead of the remote. We appreciate your patience and understanding.
2024-1-7
Dingaling
Ok thanks. I purchased a second 128GB card for the RC. I thought the drone videos would sync to the RC and from there be played. Seems not.
How about Quick Transfer from Drone to Mobile?  Then at least I could cast to a smart TV.
2024-1-8
DJI Tony
Dingaling Posted at 1-8 16:58
Hi. Yes, you can use QuickTransfer to transfer your media files to your mobile device or you can also insert the SD card into a USB reader and plug it into the USB port on your TV to watch the videos directly. Additionally, here is the link to guide you on exporting your files from your aircraft: https://support.dji.com/help/con ... p;re=US&lang=en. Have a great day.
2024-1-20
