Original Mavic help Assistant 2
387 3 1-8 04:18
Irishbogman
Flight distance : 64318 ft
I need to download the now discontinued DJI assistant 2 to calibrate my forward sensors, it is no longer available, is there another app availability that works with the original  Mavic, using DJI 4 Go on my iPad…Charles
1-8 04:18
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble. If you are using the DJI Mavic Pro, please download the correct version of the DJI Assistant 2 software using the link below and check if you can now proceed with the calibration. Please note that the DJI Mavic Pro can only be used with the DJI Go 4 app when flying. Hope this helps.
https://www.dji.com/downloads/softwares/assistant-dji-2
1-8 21:08
Irishbogman
DJI Paladin Posted at 1-8 21:08
Thank you for your support Admin, I installed DJI Assistant 2 on my IPAD tells me ive successfully installed the program but I cannot find or view the App after restarting my IPAD,  The assistant package is telling me to install the HornDIS driver, not having much luck here, hope you can help at your leisure...Charles
1-9 06:46
DJI Paladin
Irishbogman Posted at 1-9 06:46
Hello, Charles. We appreciate your response. Please be advised that the DJI Assistant 2 software can only be downloaded to your PC or Mac. iPad and mobile devices are not supported with this software. Thank you.
1-11 02:32
