battery station
1496 4 1-11 09:44
budmk21
Flight distance : 1599859 ft
I have a bs60 battery station that is about 2 years old. The lower left hand battery light is flashing red with an audible beep. It flashes and beeps wether a battery is in the bay or not. The other bays are functioning normal. Any Ideas. I have the latest firmware on all batteries, the charger, controllers, and the aircraft. I have power cycled, tried it on different outlets, different power cords so far no change.
1-11 09:44
DJI Susan
Hi there, sorry for the belated reply and the issue you encountered. Could you please double-check if it is the battery status LED or the warning LED of the station blinking red light?
Please try to use another battery and battery port for alternate testing. If the issue persists after another battery is used, or the battery is charged normally when connected to another charging port, or when charging is possible after using another battery station, it can be determined that the battery station is malfunctioning, if this is the case,  you may need to send the battery station back to DJI for further checks. You can start an online repair case here https://www.dji.com/support/repair if needed.
1-18 01:50
djiuser_7OyoVdyddoLn
Flight distance : 588373 ft
DJI Susan Posted at 1-18 01:50
[view_image]
How do we determine if it is a STATUS or WARNING?  Based on the last 2 options in your post (Beeping Description), both 1 and 2 are the exact same scenario: red flashing and beeping.
I have a battery that flashes red and is beeping. I've placed it in every slot in both my charging stations, all resulting the same.  My other sets of batteries charge w/o any issues.
So...... how do we determine if it's STATUS or WARNING?
Thanks in advance...
10-1 11:52
DJI Susan
djiuser_7OyoVdyddoLn Posted at 10-1 11:52
Hello, when charging is possible after using another battery station, it can be determined that the battery station is malfunctioning, if this is the case,  you may need to send the battery station back to DJI for further checks. You can start an online repair case here https://www.dji.com/support/repair if required.
10-1 18:20
Burt37
Flight distance : ****
I think what you wrote, if correct, does answer your question...
"It flashes and beeps wether a battery is in the bay or not."
It has to be an issue with the battery station....
Then again on your next reply you are saying something completely different...
"I have a battery that flashes red and is beeping. I've placed it in  every slot in both my charging stations, all resulting the same."
Does it flashes and beeps when the battery is in or not? That's the difference between status or warning... Battery in = status..  No battery in = warning..
10-1 20:47
