DJI Mini 3 Error 30211
1698 18 1-12 19:52
cblanco
Flight distance : 87749 ft
El Salvador
Hola acabo de comprar una batería para mi drone DJI mini 3, cuando lo puse por primera vez la aplicación actualizó la batería, después de actualizarla ya no le permite volar, me da error 30211, me pueden ayudar ?
1-12 19:52
DJI Tony
Hello there. Sorry about the trouble. It means the flight controller fails to obtain the battery serial number or identifies that the serial number does not apply to the Mini 3 model. Are you using an official DJI battery for the Mini 3? Please also provide the serial number of the battery by sending it through direct message. Thank you very much.
1-12 21:24
cblanco
El Salvador
Yes it's DJI original for mini 3, I already sent the battery serial number by personal message, thank you for your response.
1-12 22:40
DJI Tony
cblanco Posted at 1-12 22:40
Got it. Thank you very much. I see it is indeed a DJI battery. Let me forward this issue to the related team to check on this. I will get back to this once they reply. I appreciate your patience.
1-14 02:25
cblanco
El Salvador
DJI Tony Posted at 1-14 02:25
Ok, thanks
1-14 06:41
DJI Tony
You are most welcome. I will keep you posted. Have a great day ahead.
1-15 02:06
DJI Tony
Hi, cblanco. Thank you for patiently waiting. Please make sure you are using the latest Fly app version or you can try reinstalling it, If possible please use the DJI Assistant 2 software and refresh the aircraft firmware. If it still has the same issue, please send us the aircraft log, App log, exact test date, and time. You can get the Aircraft log by selecting the "Log Export", and then clicking "Save to local" on the DJI Assistant 2 while the aircraft is connected. The final exported data are ".dat" files.
For the app log, get it by powering on the DJI RC, connecting DJI RC to the computer with the Type-C data cable, selecting DJI RC on the computer, and following the path to find the APP log and exporting it: internal shared storage/Android/data/dji.go.v5/files/LOG
Please keep me posted. Have a great day.
1-16 00:59
cblanco
El Salvador
Hello, I can't attach the DAT files because of the file size
1-16 18:52
DJI Paladin
Flight distance : 318 ft
cblanco Posted at 1-16 18:52
Hello there. You may upload the logs via Google Drive and then send the link here so we can access the needed files. Please don't forget to set it as "public". Have a nice day.
1-16 19:59
cblanco
El Salvador
DJI Paladin Posted at 1-16 19:59
Ok, I attached the link to the files
https://drive.google.com/file/d/ ... t4/view?usp=sharing
1-17 06:15
ShotsByMansfiel
Flight distance : 183507 ft
Do you have another battery to try?
1-17 08:10
cblanco
El Salvador
ShotsByMansfiel Posted at 1-17 08:10
A friend lent me one but the plus version and it works perfectly, but mine gives me that error
1-17 08:47
ShotsByMansfiel
cblanco Posted at 1-17 08:47
That’s a start, it rules out the drone itself having a problem. Do you have warranty on the battery from where you bought it? You could return it
1-17 08:51
cblanco
El Salvador
ShotsByMansfiel Posted at 1-17 08:51
I bought it in the USA and I live in El Salvador, I have no warranty
1-17 09:40
DJI Tony
cblanco Posted at 1-17 06:15
https://drive.google.com/file/d/1MvlRRk4CczlqAvzKXmigbGAUwjpPslt4/view?usp=sharing
Thank you very much for your efforts. I'll forward this right away and will make sure to give you updates. I appreciate your patience.
1-20 02:45
cblanco
El Salvador
DJI Tony Posted at 1-20 02:45
Ok, I wait your aswer
1-20 06:04
DJI Tony
cblanco Posted at 1-20 06:04
Hi, cblanco. Thank you for patiently waiting. After checking with the relevant team. They have confirmed that this is not normal. I'm afraid you need to send back the battery for repair. The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. We appreciate your patience and understanding.
1-22 01:47
djiuser_oDDfGy07mPri
DJI Tony Posted at 1-12 21:24
R-41263966
4-26 11:56
DJI Tony
Hi there. Thank you for reaching out. Can you please elaborate? We are more than glad to help. Have a nice day.
4-27 04:20
