Hello DJI Reps. Regarding setting up Waypoints missions. I noticed this not long ago and no matter what I try the 3-9x camera is not selectable when setting up a Waypoints mission. The only camera is the 1-3x which I can select and change the zoom amount and save the mission with that setting. The only way to switch to the 3-9x camera is I need to connect the drone and then go into the settings and select the 3-9x camera. However, even if I select the 3-9x camera and set up the mission and try to save it the pop up window indicates it will be adjusted to work on the current aircraft model and it will not save with the 3-9x camera. Since the Air 3 has this ability I don’t know why it won’t work. Basically the only camera which can be saved in a mission is the 1-3x whether connected or not connected. Is this something DJI can fix if possible. I don’t know why either camera can’t be selected in a waypoint mission plan. Any help will be appreciated.
