liningiv
Flight distance : 329409 ft
I am suggesting taking the sharp edges off, not re-shaping the blades.
I think that you will destroy the balance of each blade if anyone does as you suggest.
But in answer to your suggestion, the props are rotating, the cowls are not, so an entirely different scenario.
The cowls are cut away on the Dreamliner to smooth the transition between the fan air and the ambient. This will reduce the noise, agreed, but the P3 is fitted with props, they are not not cowled fans. |
