bug report: change of yaw speed of drone when changing lenses
367 1 1-21 04:12
fansba3b7009
Flight distance : 314908 ft
Austria
the "FOV-Controlled Gimbal Speed" also effects the general yaw speed of the Inspire3, this makes no sense for dual operators and solo operators
there are allready  all the settings to make yaw more smooth yourself (expo and speed settings) and you get used to theses settings really fast...if you constantly are forced a channge just by the  lens you put on its impossible to fly acuartae
if you fly a 50mm lens  it spins so slow on yaw that you cant make tight turns....this is really dangerous  !! this also happens in Sport Mode ... 150 degrees/ sec on yaw is not possible anymore
this has to be switched off, at least by the user and should never mix into the drone flying settings
if this is not a bug then the Inspire 3 is seriously not made for proffessionals
please also allow to switch of "FOV-Controlled Gimbal Speed" on the gimbal ,  like on the I2
filming sports and fast action is impossible to frame like this
1-21 04:12
DJI Susan
Hi there, thank you for your feedback, we understand the request and will forward it to our engineers, hopefully, there will be an optimization. Thank you for bringing this up.
2-3 00:56
