826 Raw
Flight distance : 414226 ft
I also have the same issue; if you use the HB Monitor in Mirror mode, you get more functionality, but the zoom is still not working. I uploaded the latest firmware, v01.05.0500, where the handle needs to be connected to the HB Monitor.
After testing with Ronin 4D in Broadcast and Mirror mode, I have full functionality OTHER THAN the Mode switch. I am using the DJI 17-28mm, which I thought would work being native. The documentation here does not mention The Mode button; however, on the HB Monitor in the setting, it states that the HB monitor needs to be in Broadcast mode for the focus/Zoom function to work, which I cannot get it to.
