M300 Factory Drone and Smart Controller Reset
561 3 1-24 12:52
djiuser_Hghg8JlthQEK
Flight distance : 1413225 ft
Puerto Rico
I googled without luck to find a way to do a factory reset to an M300 I was using as part of a project that recently ended. Any clues on how to perform a factory reset or default on the drone, smart controller, and GNSS station if need be?
Thanks,
O
1-24 12:52
AR_AirPrecision
Flight distance : 2660509 ft
Belgium
On the RC there is an Factory Reset, via DJI Assistant you can also "reset" the M300. Why would you do a full reset after a project?
1-25 03:03
Puerto Rico
AR_AirPrecision thanks for your time and explanation. We were contracted for data collection and processing by the company that owns the equipment. The reason why I will do the reset is because the company has requested it once I finish collecting the project data.
1-26 05:31
AR_AirPrecision
Belgium
In Belgium, NCAA doesn't like that as they may request logs from UAS in case of investigation. If everything is wiped...they get very suspicious. Were you able to reset everything?
1-28 04:56
