Engines that stall
263 2 1-25 08:29
Ari1970
Hello everyone, what can it depend on, if I put the gas to 0 in both acro and normal mode the engines stop
1-25 08:29
DJI Tony
Hi there. In Acro or Manual mode, the Avata has no flight assistance function such as automatic stabilization which is why it is recommended to tighten the F2 stick on the rear of the throttle stick so that the stick does not return to the center and adjust the F1 screw to make sure the stick resistance is suitable. In normal mode, the aircraft hovers in place if the stick is in the center. If the engine stops midflight and the drone crashes, we suggest sending the unit back to DJI for repair. Have a nice day.
1-26 21:49
Ari1970
Thanks, I understood where the problem is, I was a bit stupid, because I was doing bench tests, so when I switched from manual to acro I had the stick at minimum, consequently the engines stopped
I'm using a translator, there may be some typing errors, thanks
1-26 22:08
