Propeller ends coming off
3212 21 2024-1-27
Yaros1
Flight distance : 25188186 ft
Hi, am I the only one experiencing the issue where the orange tips or the propellers that are rubber are randomly coming off in flight?
It won't cause a crash or anything, just something annoying, and I replace the prop because of that.
2024-1-27
Wyldwestaz10
Flight distance : 1099068 ft
The only situation where I saw some have this issue was due to the way they were storing the aircraft. They were getting rubbed off because contact was made against something in their case. I’m kind of a perfectionist so I am always careful with any of my drones especially when storing them in any hard case or soft carrying case. I also use a soft silicone prop holder on both my drones to keep them from flipping around or moving. I like that they fit loosely around the props and don’t put any stress on the them like many of the hard plastic prop holders. Something to be aware of and with very little extra time you can make sure there is nothing which could rub off the coating  while placing them into a case or once stored. So far I’ve had no problem with my Air 3 prop coating rubbing or coming off whether when storing it or after any flight. This has been asked about before so maybe DJI can change the process so it's more durable in the future.  Enjoy.
2024-1-27
DowntownRDB
Flight distance : ****
I'm not seeing that on my Air 3.  How are you storing the drone when not flying?  Could be the prop tips are rubbing against something.
2024-1-28
Sean-bumble-bee
Flight distance : 15997 ft
"just something annoying", it's more than that, it will cause an imbalance of the prop and vibrations, in terms of the resulting vibration the outer tip is the worst possible place to lose some mass.
2024-1-28
Wyldwestaz10
I agree if they’re that bad then replace them and just be careful when handling the drone especially when storing it. My silicone prop holder does help in keeping them from being damaged. I’d suggest purchasing that type of prop holder which was only about $11 on Amazon. Just another inexpensive accessory for your drone.
2024-1-28
DJI Gamora
Hi, there. We're sorry to hear about this situation. Before each flight, it's recommended to check whether the propellers are cracked, damaged, misshapen, or corroded. If they are, replace them to avoid mishaps. We thank you for your support.
2024-1-29
Jackvg83
Flight distance : 446781 ft
I have also a question about storing the drone in a hardcase. I have a feeling that, when folded, the propellors can scratch the downward infrared/laser sensor at anytime. Anyone else noticed this too? I was thinking of buying a prop holder, but i think then they may pushed extra towards the sensor.
2024-2-1
Captain-Drone
Flight distance : 11811788 ft
Hi, I too am experiencing this, the tips have come off four of my props. I check them before and after each trip and have so far replaced four props. I put a new one on yesterday just before a flight on on it's return the end was missing again. The flights were normal and without collision or contact with anything. Hand caught at the end of the flight and took off from flat and level ground. I just wonder if there is a bad batch where the glue is not good?!!!
2024-2-2
Yaros1
DowntownRDB Posted at 1-28 07:13
I'm storing it in the fly more combo bag, and also on my shelf.
2024-2-4
DowntownRDB
Yaros1 Posted at 2-4 15:04
Sounds like a bad batch of props got through DJI's QA check.  I use a prop holder when I put it in my hard case, otherwise it sits on my desk.
2024-2-5
Yaros1
DowntownRDB Posted at 2-5 04:02
Yup, this is what I thought as well.
For now my new props are holding up pretty well!
2024-2-5
virtual
Flight distance : 5161677 ft
Czechia
It definitely sounds like a bad batch of props. I fly still the first set of props that were used in all kinds of weather like sub zero temperatures...
2024-2-6
RAYMARO
material defectuoso
2024-2-6
DowntownRDB
Yaros1 Posted at 2-5 11:45
Great to hear the new props are holding up much better than the original ones.  Hope you have no further issues with props.
The good news is the Air 3 props are so much easier to change that the screw on props with the Mini series drones.
2024-2-6
Yaros1
DowntownRDB Posted at 2-6 11:15
Yes, I feel like the Air 3 is the first drone without issues since the release of the Mavic 2.
Every drone after that was flawed in some way or another… DJI Air 3 is really great, and I don't see any significant problems!
2024-2-6
DowntownRDB
Yaros1 Posted at 2-6 12:10
I'm really enjoying the Air 3 and the dual cameras.
2024-2-6
reefpix
I'm having the same issue with one of the props on my Pro 3. These set of props are < 2 months old.
2024-7-18
DJI Diana
Flight distance : 2408 ft
reefpix Posted at 7-18 20:33
I'm having the same issue with one of the props on my Pro 3. These set of props are < 2 months old.[view_image]
Hi there,
thank you for reaching out.
We apologize for the inconvenience. We recommend that before each flight, check whether the propellers are cracked, damaged, misshapen or corroded. If they are, replace them. Additionally, you may try to test flight your unit and hover it in place to check the stability.
Should you have any other questions, kindly message us for assistance. Thank you.
2024-7-19
DWrld Gster
Flight distance : 557369 ft
Mine keep coming off Air3
2024-10-12
DWrld Gster
Mine keep coming off in sport mode high G maneuvers
2024-10-12
DJI Diana
DWrld Gster Posted at 10-12 07:50
Hi there.
2024-10-12
Antdrones
Flight distance : 1253035 ft
people saying its a big bunch of defects, maybe try getting replacements on amazon
2024-10-12
