Action 4 diopter (close focus filter)
930 21 1-28 21:44
Arjuna Gallaghe
New Zealand
Has anyone managed to find a close focus filter (diopter) that fits on the Action 4?
1-28 21:44
Fishycomics
zoom in with the  sensor  lower right corner, DJI should offer us the allowance in Customes to lock it
1-29 04:28
osmonauta
Hungary
https://www.aliexpress.com/item/1005006241041855.html
1-29 05:09
Fishycomics
remember do not go under water with any aftermarket lenses, may  void the warranty, and waterproof of the  camera, water will enter through the lens if not properly screwed.
and that is a SLIP ON not a threaded product
1-29 05:15
Arjuna Gallaghe
New Zealand
Fishycomics Posted at 1-29 04:28
I find the zoom function on the action 4 looks terrible. It looses too much sensor data when it crops in.
1-29 16:25
Arjuna Gallaghe
New Zealand
osmonauta Posted at 1-29 05:09
This looks interesting. The close focus I'm after is for vlogging, not macro. I think this is too much.
1-29 16:27
lutzmix
Intermediate ring lens to 40.5 mm step up adapter
stepupring 40,5-42/43/52 etc and a closeup lens
closeup lens 1or 2 for vloggink
1-30 05:28
fansb0c2bcac
Flight distance : 128865 ft
lutzmix Posted at 1-30 05:28
Where does one find this step up ring?
5-2 06:21
Iancraig10
fansb0c2bcac Posted at 5-2 06:21
And that’s the problem. No one makes them for sale. It would be really useful if DJI made a step up converter from the cover lens thread size to say, 49mm so that we could use any filter that we want.
Lutzmix has printed his own adapter!!
5-2 08:33
johansenfoto
Flight distance : 1173379 ft
Norway
I think the reason is because there are so many people out there who don't know that the camera is not waterproof (if they remove the protective filter), and want to take it diving and then complain to dji that the camera is not waterproof.
5-2 11:07
Iancraig10
johansenfoto Posted at 5-2 11:07
Oh blimey…….
I was thinking along the same kind of arrangement as their nd filters.
The closeup filter I use for the Ace Pro is only 2 or 4X. In fact for 4 x it needs to be very close. Does the Action need more than that? (I noticed that Osmonauta’s link is to a 15 x which seems way too much)
5-3 07:05
Fishycomics
15X is a Macro.  its too bad that we can not swap out like a Pixiaero lens. made and discontinued of the Action 1  As we  wanted or not a wider range lens, we got it, going back to the 35mm style seems outdated but will catch back on eventually down the line
PIXAERO lens
5-3 07:40
johansenfoto
Norway
If only someone could make/design an adapter we could 3D print ourself that would work with maybe a 52mm filter.
5-3 13:12
Iancraig10
It would be useful or if Ulanzi  made a case with adapter on the front, like the GoPro ones.
5-3 13:37
lutzmix
43mm/52mm/55mm
55mm close up lens +2
5-3 22:50
johansenfoto
Norway
lutzmix Posted at 5-3 22:50
43mm/52mm/55mm
Have seen yours before, is it put on top of the second filter? I would like to have one that replaces the old one with screw on and up to maybe 52mm
5-4 00:35
Arjuna Gallaghe
New Zealand
That reduces the image quality
5-4 00:46
Arjuna Gallaghe
New Zealand
43mm/52mm/55mm
[Image]
Does a 43mm adapter work? Doesn't it need 40.5mm?
5-4 00:49
lutzmix
5-5 11:07
lutzmix
Arjuna Gallaghe Posted at 5-4 00:49
you can try the silicone lensprotector with s 39mm stepup ring
or the tilta cage and a stepup ring
tilta has its own filter
With the old Dji smallrig cage you could screw a step up ring onto the housing, this would be possible with the Tilta cage (DIY solution)
5-5 11:13
Arjuna Gallaghe
New Zealand
lutzmix Posted at 5-5 11:13
Does tilta make a close focus adapter that fits their cage?
5-5 11:31
osmonauta
Hungary
What is the thread size of the Action 4 lens? Is it 39mm? You can get a 39 to 43mm step-up ring here. There are other sizes available from the dropdown menu:
https://www.amazon.com/Fotasy-39 ... /dp/B007GX56YO?th=1
...and then you could use this Vivitar 43mm close-up set with 1, 2, 4, and 10 diopters:
https://www.bhphotovideo.com/c/p ... lose_up_filter.html
5-5 13:26
