Mavic 3 PRO Ipad issues
349 9 1-30 00:40
Wallie78
Flight distance : 5402064 ft
Hiya, running an ipad with a Mavic 3 pro and horrible latency with the image when recording and watching live transmission.
Have cleared cache, checked space on Ipad...what am I missing?
The ipad works perfectly with my P4P? Why not the MP3?
1-30 00:40
Labroides
Flight distance : 9991457 ft
Probably because the DJI Fly app is more demanding than the older, DJI Go 4 app.
You probably need a newer tablet with a faster processor and more RAM.
1-30 01:37
Wallie78
Labroides Posted at 1-30 01:37
Yep assumed this may be the case, thanks for your help :-)
1-30 01:43
Wallie78
It is an iPad mini 5th generation?
1-30 02:17
DJI Tony
Hello there.  Please ensure the latest version of the DJI Fly app is installed. You can download the app here: https://www.dji.com/downloads/djiapp/dji-fly. You can try cross-testing with another compatible mobile device to check whether the compatible issue causes it. Have a nice day.
1-30 02:21
Wallie78
DJI Tony Posted at 1-30 02:21
Hi Tony, I did a clean re install so def the latest app. Should I have any issues with an iPad 5?
What else can I try to work out what is the issue?
1-30 02:57
DJI Tony
Wallie78 Posted at 1-30 02:57
Hi. The Fly app was tested and confirmed to work with iPad Pro, iPad Air 2, iPad mini 4, iPad Pro, iPad Pro 2018, and iPad Pro. The iPad 5 stabilization has not yet been verified.
1-30 03:23
Wallie78
Thailand
DJI Tony Posted at 1-30 03:23
Why does it work for iPad mini 4 and not 5???
2-15 01:50
DJI Tony
Wallie78 Posted at 2-15 01:50
Hi. It is not yet officially confirmed whether it works or not on the iPad Mini 5. It is not tested yet thus making it not verified. But generally, devices not listed as supported mobile devices can also be used if their system versions are the same or later than those published on the DJI official website (Beta system versions may not be compatible)
2-17 01:52
Wallie78
DJI Tony Posted at 2-17 01:52
It’s got better specs than the iPad 4 yet it doesn’t work properly. How can I fix it as I don’t want to go and have to buy another iPad
2-17 02:35
