walter_junior
Brazil
LV_Forestry Posted at 1-31 11:08
For sunny days, with lots of sparse clouds, there is not much to do. In any case it is certain that it is not with the piece of white plastic that you are going to solve the problem of the shaded areas which create contrasts in the images. Unless you put them all over the field.
The reflectance target, with DJI drones, can just be used to give a pseudo-reference on the calibration of the camera which is not provided as for a more "serious" camera. If you want really accurate results, go your way with DJI, invest in something else. Micasense, Sentera...
Okay. Thanks for your reply. I also read the discussion provided by the link. However, I currently have M3M and Pix4D Mapper Pro. As I'm new, I still have questions and ask for help:
To obtain more accurate vegetation indices regarding planting conditions and compare the results obtained in different flights carried out on different days, should I use the calibration panel (I have from Micasense) or would the M3M's light sensor be sufficient? |
