Flying Peacock
DJI Wanda Posted at 2-2 23:25
Hi there, about the issue you mentioned, here are several ways to help you further confirm. First, could you please confirm whether are there any upgraded versions of your mobile phone system and Blackmagic Cam App? If you have an upgraded version, the reason why it cannot be externalized may be due to the version upgrade. It is recommended that you use the DJI Mimo App (which requires the latest version) for recording. Or use these two apps (Filmic Pro, Protake) to record. Second, if your mobile phone or Blackmagic Cam App has not been upgraded, you can turn off the transmitter and then test whether the phone can play sound normally. If it still cannot play sound, there may be a problem with the phone. Third, if your phone can play sound after turning off the transmitter, it is recommended that you use the DJI Mimo App or other two apps (Filmic Pro, Protake), and then test whether the phone can play the sound normally.
Hello Wanda.
Thanks for your reply anf information. As far as I know I have the latest version of everything. I have DJI Mimo and I am using it with my DJI Mic 2 and my Osmo Mobile 6 Gimble, using Bluetooth and they all seem to be working fine. I am waiting to hear back from back from a post I put up on Blackmagic Cam Forum.
I will try using DJI Mimo and Mic 2 only. The iPhone is working fine. I spent an hour with Apple Tech Support going over all the various combinations that could be a problem with the iPhone Mic and it is working fine. The DJI Mic 2 shows up as being connected on Bluetooth but does not show up on the Mic Settings on my iPhone.
Oncea again, thank you for your suggestions. I will try again later today.
Best regards.
Ian. |
