leon.hughes
Hi,
I've just upgraded my firmware / app (iPad Air2) to the latest version. Made two succesful flights, but then received a compass error in mid air. This has never happened before and I was at 80 metres in height well away from any sources of magnetic interferance in an open field. The Phantom started to drift very quickly to the left and would not accept any stick inputs accept altitude. I managed to ascend to 120 Metres to buy some time, then switched to ATTI mode when I was able to bring the aircraft back. The compass then seemed to rectify itself and I was able to switch back to P mode and fly as normal. This was the first time I'd even tried ATTI mode but it seemingly saved the Phantom from a crash. Has anyone else seen this? Should I get the craft looked at by my local repair centre? Also, if the switch had been locked in the settings so that it couldn't switch out of P mode would I have been stuffed?
Also, I calibrated the compass prior to flying and it was showing at about 1400 in the sensors menu.
Thanks in advance for any help!
Leon.
