LV_Forestry
Flight distance : 4726654 ft
Latvia
Well, I understand better what your problem is.
First, you can safely use the base station, provided you are relatively close to it, 30km is too far.
(Sorry, You will have to copy the coordinates manually, the forum interface does not allow me to publish a series of numbers. Ineffective anti-spam policy implemented recently.)
You can try to redo the process with these new coordinates. Not sure if it helps, because calculated from a 2h file, the result can be more than uncertain. And anyway as mentionned before, its too far away.
Then, when you say altitude taken with Google Earth, in reality you are referring to the SRTM4 reference model, used by Google, which is purely indicative.
The resolution of the original file is 30m, which means that the extrapolation can generate enormous errors.
SRTM | NASA Earthdata
I find the center of the antenna at 7.99m from the ground (according to Google Earth model... SRTM4) Which is of absolutely no interest because the coordinates of the base station are correct. So your altitude error does not come from there.
Using the SRTM for geographical work is really not recommanded. To give you an idea of the differences that can be found, today I did a survey on a road. A point measured at 3.70m high in reality, is at 1.91m on the SRTM. 1m79 error.
50m further I measure a point at 3.37m high, on the SRTM it is at 3m exactly. 37cm error.
And this is in the center of Riga which is relatively flat. I let you imagine in a mountainous environment with very pronounced relief what the margin of error can be. In fact, no need to imagine, look at the results you get.
I propose the following workflow:
-Do your survey with your Lidar L1 connected to a base station not exceeding 25km away.
-Output the point cloud on DJI Terra using the EGM96 geoid.
-Use it as a reference to generate DEM / DTM...
You can also use it as a reference to set the altitude of the GCPs if you want to do photogrammetry from the L1 photos.
If your client requests georeferencing in the national system, think about using the appropriate geoid instead of EGM96 !
ITA2009 for example.
And finally, if you still need to refer to an existing model, you can use more precise models than the SRTM, like this one:
Tinitaly
Using this one for comparison, I find 50cm difference with the SRTM at the coordinates of the base station, and 14m at the takeoff point of the drone...
I think the evidence is clear.
