JJB*
Flight distance : 12445630 ft
Hi,
You started this flight without a GPS lock, zero GPS sats!
After manual takeff your Mini3Pro used the vision to stablize.
Changed Flightmode to Sport.
At 18s into ATTI mode beacuse Vision lost its reference, so no more Vision assist to keep craft stable in the horizontal path.
In sport mode with full stick forward drone has difficulty to keep height steady, this in a GPS mode and apparanly also in ATTI mode.
Did you screen record your flight? So you can look back the warnings on the screen!
See my charts of your data.
As you already know ; always wait for the white GPS icon top left FlyApp screen. White = sat lock + HP set.
Flying away with a RED icon will result in ATTI mode when Vision gets out of range or cannot get good rererence to the surface below the drone, loosing reference above water happens more that loosing reference above a 'ground' surface.
In ATTI mode drone is not really limited in pitch up or down angles, your drone somepoint 40 degrees nose down at 100% forward stick, reaching max speed 16.1 m/s.Last speed in log before ATTI mode = 15.6 m/s.
Forward stick to zero and 100% up stick does not mean that drone will climb at the same time, it looses height before climbing.
Flying low above water, not enough free air below drone the recover and climb.
Height is controlled by the barometric sensor, also in ATTI mode. But height is not always steady with large and rapid RC inputs.
Let say you are flying at 10 meter baro height, in sport mode fly max forward to max aft stick with other inputs (not UP) as well. Do not think that a MINI3Pro will fly steady at exactly 10 meter during all those rapid RC inputs. In Atti mode attitude changes are more rapid than in a GPS mode.
Baro height indication can show incorrect height values due to rapid pitch changes as well. So height values in the log does not always show the actual height.
IMU error? don`t think so, but wait for DJI to make their assesment.
cheers
JJB [ Charts by FRAP ; the 'best' software for data and visual flightlog analysis (www.jjbfrap.eu) ]
