DJI Mic 2 transmitter gain v's onboard recording level
862 3 2-1 12:34
Poitings
I have a DJI Mic 2 single TX (transmitter) and a RX (receiver) cold shoed into my Sony ZV-1 camera for recording video.
The gain on the camera settings are dialled down to 1 (some people even set it at 0), the gain on the receiver that is connected to the camera via mini jack is set to +9.
So I'm trying to understand what the idea gain setting for the transmitter should be?
I'll mostly be in a quiet room doing talks directly to camera with the transmitter clipped to my shirt.
Another question is about the onboard recording level for the transmitter. I did a test and it's super quiet.
Is there a setting for the transmitters on board recording level or is that just the same as the transmitter gain level.
If so, then I guess my questions are 1. Is a gain of +9 about right for my receiver. 2. What should the gain level for my Transmitter be?
2-1 12:34
DJI Gamora
Hello, there. Thank you for sharing this query with us. Please allow us to check this query with our relevant team for further confirmation.
2-3 00:05
Poitings
DJI Gamora Posted at 2-3 00:05
Ok I look forward to your answer.
2-4 10:14
DJI Gamora
Poitings Posted at 2-4 10:14
Hi, there. Thank you for your patience. Regarding this matter, please refer to Instructions on Recommended Gain for Camera Setup via this link. Furthermore, the  DJI MIC 2 TX gain can be set to 0 and RX gain set to +9 to use. DJI MIC 2 TX independent recording gain is the same as the TX gain set on RX. I hope this information helps. Thank you for your support.
2-8 00:49
