GO app - remote not pointing in proper direction
1466 2 2015-9-9
chris.green.ima
Flight distance : 13901 ft
In the go app the map shows a circle representing the remote and shows the direction it is pointing.  The pointer indicator is almost 90 degrees off on my display.   What provides the direction indicator for the remote?  GPS typically cannot determine direction unless the unit is in motion.  Ideas?
2015-9-9
houston
Flight distance : 21241217 ft
Also, make sure your map is in North up orientation. Tap the compass icon.
2015-9-9
chris.green.ima
Haha... will check it out but it's not the North orientation as it's pointing wrong relative to everything on the map including the inspire.  Using an ipad mini 2.   Will try my iphone.
2015-9-10
