Sigma 16-28mm f/2.8 DG DN Contemporary?
234 6 2-2 08:11
Superluminal
Flight distance : 1141191 ft
Anyone tried it?  It's not on the lens compatability page.   I'm new to the 4D, does that mean it definitely won't work?
https://www.dji.com/ronin-4d/lens
Cheers.
2-2 08:11
DJI Susan
Hello there, as per checking, Sigma 16-28mm F2.8 DG DN is the compatible lens. You'll need a counterweight for balance. You may double-check on the website. Thank you for your attention.
2-3 04:49
Superluminal
DJI Susan Posted at 2-3 04:49
Hello there, as per checking, Sigma 16-28mm F2.8 DG DN is the compatible lens. You'll need a counterweight for balance. You may double-check on the website. Thank you for your attention. [view_image]
Sorry, I should have specified for Sony e-mount.   It’s only on the list for L.
2-3 05:40
DJI Susan
Superluminal Posted at 2-3 05:40
Thank you for your clarification, I will double-confirm with the engineers to see if they have further information. I will keep you updated.
2-4 00:24
Superluminal
Thanks Susan!
2-4 05:35
DJI Susan
Hello, thank you for your patience. There is the reply from our engineers.
1. The weight of the E-mount Sigma 16-28mm f/2.8 DG DN lens is within the range supported by DJI Ronin 4D. In theory, it can be used on the Ronin 4D. However, since no relevant compatibility tests have been conducted, if you have this lens, you may try it out with the Ronin 4D.
2. If you are trying to use this lens with the E-mount, you can try to manually calibrate the lens before using it. Thank you for your attention.
2-5 06:51
Superluminal
Thanks for the info Susan.
2-5 08:25
