JAM1410
DJI Tony Posted at 2-6 00:26
Hi. No need to bind the remote again, but for the flyaway benefits concern, it is recommended to bind the remote when using the Mini 4 Pro. You also don't need to manually link again, but you need to manually switch the corresponding aircraft model in the goggles first. Have a great day.
I'm not sure I understand the difference between bind and link. You are saying that for benefits of flyaway I would have to bind to Mini 4 Pro. Isn't linking controller to it once does the same thing?
For example:
Let's assume that I linked goggles and controller to FPV and to Mini 4 pro. Then I used it with FPV for for some time. Next I decided the other day to go with Mini 4. So I switched in googles to Mini 4. Is it already linked and bind to Mini 4 or you recommend to relink it to Mini 4 Pro again?
