Mavic 3 Crash - Drone flew forward without me controlling it
307 3 2-6 19:12
chreesh
Flight distance : 792808 ft
Hey all,
Had a pretty crappy night and panicking now how much I'll have to pay in repairs. Trying to understand why my Mavic 3 flew forward without me controlling it to do so.
I have uploaded the flight logs to Phantom Logs to try understand what may have went wrong
I arrived down at the location this evening. A location I have flew from many many times and never had a single issue.
I powered up my drone and noticed a few errors pop up mainly ambient light too low, I was sat in the car at the time with the drone not in motion trying to gage what ND filter I would need as I was planning on taking some long exposure shots of City hall, so gathered that was the cause for that as once I was out of the car this disappeared.
Once I had determined the correct ND filter I got out of the car to take off and got a warning saying I needed to calibrate, so I spend some further time recalibrating the drone. Once I had done this, it all corrected itself. This was up to around 32 seconds in the logs, Can be seen that the drone never went higher than 5 foot to this point as I was calibrating the drone. While hovering, I had noticed the two errors that came up between 10 and 14 seconds and again from the logs it can be seen I never raised the drone, I corrected the issues before hovering the drone again.
After checking multiple times that everything was working as it should and I was receiving no further error messages I began to ascend around 50 seconds into the log.
At around one minute as I was slowly ascending I noticed the drone randomly started to fly forward, I tried to correct this by pulling back but to no avail. It was at 1 min 3.9s the drone collided with the building.
I have noticed from looking at the logs that the location is incorrect as by looking at the map it's showing I took off a few stories up on a roof... where as I took off beside the "Margot" building.
My instant assumption was that possibly I had lost GPS and my drone had went into ATTI mode but there's no indication this was the case as the drone was in P-GPS(BRAKE) the entire time and never entered ATTI. I can see the satellites dropped but that was already after the drone stopped responding to me.
Happy to share the Phantom logs if anyone can help me possibly understand what went wrong, if it was my fault or an issue with the drone. If it makes any difference with regards to signal I'm using an RC Pro controller.
2-6 19:12
Hi there, we are sorry to know about the accident. We recommend that you start a case through the link below and send the drone in for diagnosis and repair. If there is a doubt about the accident, data analysis can also be applied as long as the drone is within the warranty period. http://www.dji.com/support
2-6 19:49
chreesh
DJI Mindy Posted at 2-6 19:49
Hi there, Thanks for the reply. I have opened a case and received a shipping label so I assume it is still under warranty as it states if it isn't you have to arrange your own shipping.
Is there anyway someone from DJI can look at the log before I send it in as if it is a user error and not a drone error there isn't much point me sending it in as I'm not sure I will be able to afford the repairs due to our first baby on the way and I would be best just selling it for parts.
2-6 20:09
chreesh Posted at 2-6 20:09
You can check the Warranty Period through this link. https://repair.dji.com/device/detail?lang=en&re=us If it's under warranty period, you can contact our support team through email or online chat and provide the log to apply for data analysis. http://www.dji.com/support
2-6 22:33
