djiuser_fl0AG9OqVP1T
Flight distance : 101175 ft
Dirty Bird Posted at 2-7 14:42
You can already do this. After creating a mission select a waypoint, then set Heading, Gimbal Tilt, & Zoom to "Manual". Next select "Apply To All". When launched the drone will fly the waypoint route at the set speed(s) while allowing you to control yaw, tilt, & zoom manually with the controls. There is no Manual setting for mission speed so I am uncertain if forward/back on the right stick will speed up or down? Otherwise see if it allows you to set the global speed to 0 at which point forward stick may allow you to control speed. You will have to try it with a test mission.
Thanks. Just read in the manual (pg. 44, section 5b) that the stick *can* be used to change flight speed. I wasn't aware of this, and did not want to risk aborting the mission by touching the controls. Anyway, that at least makes manual speed change possible, regardless of what it was set at when uploading the mission.
What I would like is for all settings (including heading, camera tilt and zoom) to allow manual over-ride during flight. Even for POI facing waypoints, the camera angle can be off (for instance, when the POI's real altitude is negative), hence manual control is desirable. Once the sticks are released, the drone can return to the original settings. |
