Goggles V2 used with FVP no live audio
2272 11 2024-2-8
Shayne Lory
Flight distance : 751407 ft
Is anyone having any issues connecting a headset to your V2 goggles and hearing love audio from when you’re drone is in flight? I have a buddy of mine who hooked up a headset and it works great. I do the same thing have the same settings and mine only works on playback not on live flight. Has anybody had this problem and been able to fix it?
2024-2-8
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The DJI FPV drone only supports sound recording when shooting a 1080p video at 60 fps. You will be able to hear the sounds recorded by the DJI FPV drone in real-time, but you can hear the sounds when playing back the video on the DJI FPV Goggles V2. Please note the function of the audio port of the DJI FPV Goggles V2:
1. The DJI FPV Goggles V2 supports playing videos that are not shot by the DJI FPV drone, and you can connect headphones to the goggles to hear the sounds of these other videos.
2. It can receive (AV) audio/visual signals from electronic equipment. When the DJI FPV Goggles 2 are connected to a third-party analog image transmission receiver, the audio port is used to receive analog image transmission signals.
2024-2-9
Shayne Lory
DJI Paladin Posted at 2-9 01:26
So let’s clarify this. I have switched in my camera setting over to 1080p/60 And I still do not have sound when I take off in my earpiece after I hit the record button. Are there any other settings that need to be changed?
2024-2-9
Shayne Lory
I don’t know maybe you left out the word not? Because I have watched several videos of people saying that they can hear sound during live flights. I have witnessed it firsthand with a friend of mine. I just don’t understand why mine is not doing it.
2024-2-9
Shayne Lory
They sell a headset that attaches to the V2 goggles for $70 so that you have audio while you’re flying something is wrong and I don’t know what it is and I just have to believe that it’s in my settings. I can hear audio when playing back some videos from the drone itself, not the videos from the Goggles.
2024-2-9
DJI Paladin
Shayne Lory Posted at 2-9 07:04
Thank you for your response and we do apologize for the trouble. We will coordinate this with our relevant team for further clarification. We will keep you posted.
2024-2-12
DJI Paladin
Hi there. We have receive an update with the relevant team. With the recent firmware of the DJI FPV Drone (v01.04.000) paired with DJI FPV Goggles V2 (v01.07.0000) it does not support real-time audio recording and firmware downgrade. Real-time audio recording may be intermittent. We appreciate your understanding and support.
2024-2-19
fans73f7cc83
Flight distance : 52165 ft
So I’m having this issue. So your answer is I have to downgrade in order to have live audio. How do I downgrade my firmware
2024-3-14
Shayne Lory
Actually, you cannot downgrade. Unless you root the goggles, you can do that by watching some videos on YouTube. However, it is not recommended and will avoid your warranty. What I did find out was that if I restart my drone several times and goggles and depending on a certain cycle, the audio will come back.
2024-3-14
know1fpv
Flight distance : 1987474 ft
This also happens to me. I've had the the FPV for over three years now, but within the last 6-9 months I've started getting intermittent live audio through the headphones connected to my Goggles V2. I also figured out that restarting the drone a couple times the audio will come back, but this is still very frustrating and hope theres a solution
2024-8-14
DJI Natalia
know1fpv Posted at 8-14 07:00
Hi there, thank you for reaching out and sharing your experience with us. We truly understand your concern and we will consider this as a suggestion. Your valuable feedback will be promptly forwarded to the relevant team for a thorough evaluation. We would like to assure you that we are committed to providing the best user experience.
Thank you for your continued support.
2024-8-15
djiuser_g165iplNTgs2
Flight distance : 164652 ft
So if the DJI FPV drone wasnt updated then it still works normally?
Thats my favorite part of the DJI FPV and my original DJI Air Units with the Mic inside them!!
I have gotten Live Audio to work with them on my DJI Goggles V2, but only when theres no SD card in my Air unit, otherwise it records to the Air unit.
One thing i wish the O3 had was the microphone. I dont care what anyone says, if you dont need it you need to use it then..
Anyway, one thing is to make sure when you're in the DJI FPV live view to use the rocker switch to adjust the Volume and make sure its not Muted. Otheriwse maybe Roet them, and then update the Goggles to the newest FW.
2024-9-18
