Jan Spacil
Flight distance : 115299 ft
Czechia
Hi,
@Serg SSA: thanks for YT videos, I've watched them in the past (+ some other videos) and wondered why HDMI out wasn't working in my case. That was the reason I made the post. I tried three devices, without a success:
1. Cheap USB-C > HDMI adapter, not working
2. USB hub with HDMI out, not working:
3. HDMI capture card. In this case it is understandable that the adapter was not functional, the 'video direction' here is the opposite:
Finally, I tried yesterday a travel USB hub from Dell and finally it works!
So HDMI output from the RC2 is indeed possible, you just need to find a suitable adapter that the RC2 will 'get along' with.
It's another reason for me to get a Meta Quest 3 goggles sometime in the spring, where the HDMI input is also a bit more complicated but possible via capture card. Hopefully, it will work together
In any case, it's confirmation for me that I can use either a tablet or a phone with a bigger display and solve the problem with the small LCD inside the RC2 (I just can't see well anymore). Fortunately, after connecting an external HDMI, the image is also displayed on the RC2's display, so if there are problems, the drone can still be controlled.
@fans0a1e8864: This is an unpleasant problem, did the same problem occur when using an external monitor, or did you try just the TV monitor?
I have the drone set to auto RTH in case of connection loss, but it's still a risk.
Thanks for the warning, so I will try the connection only in safe conditions and if the solution works and there are no problems, I will fly in the field afterwards.
