DJI Mic 2 - Charge receiver through USB-C while connected?
791 1 2-9 06:40
mensa84
Austria
Hello,
is it possible to charge the receiver of DJI Mic 2 while connected via USB-C to the MacBook?
I know that was not possible with Mic 1 and I don't know the reason for it. Is it possible now with Mic 2?
2-9 06:40
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The DJI Mic 2 can be used while charging. You may connect your DJI Mic 2 receiver to your computer using the Mobile Phone Adapter (Type-C or Lightning) then connect the Mic 2 receiver to a 5V2A charger using a USB-C cable plugged into the USB-C port of the unit to simultaneously charge the receiver. Hope this helps.
2-10 01:09
