The Duck
Do you have "VTX (MSP + Displayport)" on UART 4, or just the MSP/Configuration switch turned on? Try setting VTX MSP+Displayport for UART 4.
Some other thoughts: Do you get a "Motors started / Motors stopped" when you arm and disarm your quad? Does the fly time start after your arm the quad? Not the one from the Betaflight OSD, but the one from basic DJI OSD. If you get those messages and/or the fly timer starts working, it means that the VTX is getting the armed signal and so are your Goggles.
Another idea... Did you make a backup of your Betaflight configuration (dump all in the CLI) and can you restore it?
If you're sure that you didn't update or change anything in Betaflight, then I would try replacing the flight controller. If it works after that, you can then rule out the DJI O3 VTX. The SpeedyBee F405v4 might be drop in compatible with the v3. But of course you will need to solder your receiver, GPS, etc. It's a lot cheaper than replacing the VTX.
I've only been flying FPV quads for 3 years, so I guess I'm new to it too. But I can definitely empathize with you. Sometimes even the simplest problem can be frustrating to diagnose and fix. And the hobby is really expensive.
So far I have:
* The camera on my Air Unit glitch out on humid days. It turned out to be an adhesive that in the camera that was causing the problem.
* Bought a horrible Skystars stack with a broken FC and horrible ESC with AM32
* Bought a couple of eMAX ELRS receivers that have horrible range. Spent hours swapping antennas. Gave up and bought cheap $10 receivers from Aliexpress and they work perfectly.
* I somehow broke a TBS Crossfire Nano RX's telemetry sometime after I had a crash.
* Installed wtfos on my Goggles V2 and they rebooted on me three times, leading to crashing a big 7" drone.
* Found a bug in Betaflight 4.4.3 and 4.5-rc that causes the flight controller to freeze and had a quad drop out of the air twice.
* Had a TBX Nano TX's LED light die.
* One of the gimbals on my Jumper T-Pro broke (wire broke inside the controller.)
* Made the mistake of buying an SMO 4K (a decased Insta360 camera.) A really bad camera.
Welcome to the hobby! |
