Green Artifacts on Mavic 3 D Log footage
248 8 2-9 14:18
Eric Bartolo
Flight distance : 21877946 ft
Malta
Can anyone explain these weird green artifacts all over this footage taken with the DJI Mavic 3?
Video Link -
Settings D-Log, 400 ISO , 1/320 Shutter , F10
Appreciate your help!
2-9 14:18
DJI Susan
Hi Eric, could you please upload the original video to Google Drive or Dropbox, then provide me with the download link? I'll download it for a check.
2-9 17:47
Eric Bartolo
Malta
DJI Susan Posted at 2-9 17:47
Hi Susan,
Thank you for getting back to me.
You can download the original copies of the files as shot from the drone here - https://we.tl/t-iTUt0HDIey
I've also included the srt & lrf files as well.
These were shot in H.264 which should be better quality than H.265 and converted to via Handbreak on mac to H.265 lossless quality.
I look forward to hearing your feedback. Thank you.
2-10 13:51
DJI Susan
Eric Bartolo Posted at 2-10 13:51
Hi Susan,
Hi Eric, I downloaded the original videos you provided and checked them via 2 video players, all the original videos are fine, and we haven't found any green artifacts as you mentioned in your YouTube video.
It may be a video editing issue,  what video editing software are you using? You can try to contact their Support to see if there are any recommendations for this.
2-10 19:23
Eric Bartolo
Malta
DJI Susan Posted at 2-10 19:23
Hi Susan, thank you for checking them out. Did you only watch the videos in log didn't try applying DJI's conversion lut from d-log to rec709 I think right? That is when the problem is happening as on log it is barely noticeable.
I'm using Davinci Resolve which I've been using for over 4 years now. Will try and contact support. Thank you.
2-12 00:50
DJI Susan
Eric Bartolo Posted at 2-12 00:50
Yes, I watched the videos in Log, thanks for your clarification, as the issue you mentioned, I'll forward it to the engineers for further checking and will keep you updated. Should you have any updates from Davinci, please let us know.
2-12 02:14
DJI Susan
Hi Eric, we have applied the D-Log to Rec.709 LUT to your video through PR. We still haven't observed the issue you mentioned in the YouTube video. Everything seems normal. If possible, you can try PR as well.
2-13 01:52
Eric Bartolo
Malta
DJI Susan Posted at 2-13 01:52
Thanks a lot for checking, it must be an issue when converting the files to H.265 then, converting to prores with a different app seemed to work fine and eliminated the issue. thank you Susan!
2-14 06:23
DJI Wanda
Eric Bartolo Posted at 2-14 06:23
It's our pleasure. Should there be any further questions, please feel free to contact us.
2-15 00:17
