View/Transfer Recorded Videos From RC 2?
335 6 2-9 21:12
generalZod
Flight distance : 1633921 ft
Hi everyone, is there a way to move/copy recorded videos and photos from a microSD card inserted into the RC2 controller? I can view the media on the SD card under Aircraft Album but if I plug the RC2 into my computer via USB cable and try explore the contents I can only see the onboard storage, not the SD card. Do I just need to break down and get an SD card reader or is there a way to make this work?
Thanks!
2-9 21:12
DJI Tony
Hi there, generalZod. Thank you for reaching out Your media files are stored in the SD card inserted in the aircraft. You can refer to this link to be guided: https://support.dji.com/help/con ... p;re=US&lang=en. Have a great day ahead.
2-9 21:18
generalZod
I guess I was hoping for a way to copy the card contents without having it inserted into the aircraft. Transferring large files via QuickTransfer still takes long enough even with optimal speed that I am uncomfortable with how hot it gets while sitting still. Essentially I want to use the RC2 as a microSD card reader, bypassing the need to proxy through the aircraft.
2-9 21:21
Labroides
Flight distance : 9991457 ft
generalZod Posted at 2-9 21:21
The fastest and simplest way to transfer the image files from your drone is to buy a cheap usb-SD card adapter, pop the card, put it in the adapter and put that in your computer.
No need to turn the drone on and it's faster than other methods as well.
2-9 21:55
djiuser_kdN8AH35wwmQ
Malaysia
I have DJI mini 2 se and I only take non raw photo, can I use u1 SD card (kioxia exceria 32gb), since I take.photos only
2-9 22:05
Serg SSA
Flight distance : 6406329 ft
Russia
If you have a mini 4, then you can connect it to your computer without turning on the power. The drone will not heat up, but the drone will work as a card reader, you will see your card on the computer.
2-10 00:12
generalZod
Thank you Serg SSA - that did the trick for me. I have a Mini 4 Pro (forgot to mention that in the original post, was up late) and I plugged it into my PC without powering on the aircraft - Voila! I can browse both the Mini4 internal card and the inserted microSD.
Thanks!!!!
2-10 06:41
