DJI Mic low level recording
997 4 2-10 05:08
SavageBeast
Switzerland
Hi everyone !
Not sure how to proceed with the DJI Mic TX and its internal recording. I have checked the RX and it is configured as MONO, so the backup should not be configured to -6dB.
But when I use the DJI Mic TX standalone, recording my voice by pushing the REC button on it, the recorded sound level is very low. How can I fix it, to have a normal recording volume ?
Thanks, Michel
2-10 05:08
DJI Susan
Hi Michel, to obtain optimal audio recording quality, we recommend that you increase the gain when monitoring and place the DJI Mic close to the sound source when recording.
How many transmitters do you have? Is it possible to try other transmitters under the same gain settings to see if it is the same.
2-11 01:04
SavageBeast
Switzerland
DJI Susan Posted at 2-11 01:04
Hi Susan, many thanks for your reply.
I have increased the gain by +6dB, and should give it a try, if it works as desired. I still need some practice with the settings and using the DJI Mic.
Have a nice weekend.
2-11 08:12
DJI Susan
SavageBeast Posted at 2-11 08:12
Hope it helps, please keep us updated once you have tried it, should you have any further questions on using DJI products, please feel free to contact our Support or ask here in this forum.
2-11 19:10
Schenk75
Flight distance : 7228 ft
Switzerland
Same problem with my mic2's. In connection with the Lumix camera the recording level is strong even at 0dB. Recording stand alone I get a very weak recording level, which cannot even be compensated with  adjusting the gain by +12dB.
10-24 09:18
