Negative Noise Reduction?
2033 15 2024-2-11
utkin
Flight distance : 237733 ft
Singapore
In Picture adjustment settings I see Noise Reduction that can be set to nevgative values. Assuming 0 meaning noise reduction OFF what do negative values mean?
And if 0 does not mean NR OFF, what value would effectively switch off the NR processing? I prefer doing noise cleaning in post.
2024-2-11
JerryLaurence
Flight distance : 21988 ft
I’ve tried unsuccessfully to get an official and definitive response to this and the same with Sharpening. My best guess is that -2 means off because I can’t believe they would add extra noise or softening.
2024-2-11
RayNY
I would set mine to -5 if I could.  Even at -2 there seems to be too much noise reduction.
2024-2-11
utkin
Singapore
@DJI Support - it looks like Pocket 3 User Manual is incomplete as it does not cover Sharpening and Noise Reduction seatings at the very least. I am wondering how the product was signed off for release with such lapses.
Can @DJI Support clarify values of both parameters? In particular I would like to know at what settings NR and Sharpening are not applied.
2024-2-11
DJI Tony
Hi, utkin. Let me check this with the relevant team. I will get back to this with an update. Thank you for your patience.
2024-2-11
Aavis
Flight distance : 328 ft
Finland
This is interesting topic and how both affect battery life. What settings use less/more processor power.
Negative values.. It.. adds... noise pixels to otherwise clear image? haha
Or is it just +2 +1 0 -1 -2 looks better than 0 1 2 3 4 5? Or what.
2024-2-11
utkin
Singapore
DJI Tony Posted at 2-11 21:09
any updates regarding the query?
Am I the only one who feels that Osmo Pocket is just another DJI product released unfinished in a rush?
2024-2-16
DJI Tony
utkin Posted at 2-16 07:07
Hi. I'm also waiting for a response. I will give them a follow-up. Rest assured I will give you an update as soon as they reply. Thank you,
2024-2-17
4wd
Flight distance : 545817 ft
In sharpening you could easily imagine negative = less sharpening and positive = more sharpening.
As for noise reduction well 0 must be default so you can increase or decrease "the reduction"
It won't be a way to adjust how much noise you add, or subtract.
Nonetheless it seems a simple enough question to confirm.
That should not take weeks
2024-2-17
utkin
Singapore
4wd Posted at 2-17 02:27
Precisely! I am wondering myself why it is taking that long especially that it is clearly DJI fault forgetting to include important information in the user manual.
2024-2-17
utkin
Singapore
DJI Tony Posted at 2-17 02:07
please tell your managers that such response time is unacceptable if DJI still aims to be a respectable business.
Please do not forget the very question
"at what settings NR and Sharpening are not applied".
2024-2-17
DJI Tony
utkin Posted at 2-17 18:03
Hi. I sent exactly what you asked. Sorry about the trouble. The relevant team is also handling other concerns. Thank you for your patience.
2024-2-18
DJI Tony
Thank you for patiently waiting. We want to make sure we are providing accurate and official responses to any questions. Based on the relevant team, the output of the images by the camera is all processed by each manufacturer's algorithm, which is why there are differences in the images of cameras from different manufacturers using the same sensor. The sharpness/noise reduction value "0" in the Osmo Pocket 3 settings is the initial parameter we set. For the camera, there is no on/off noise reduction function. Have a nice day.
2024-2-20
utkin
Singapore
DJI Tony Posted at 2-20 03:39
You mean to say that we cannot turn noise reduction completely? But -2 settings would apply minimal damage to the captured video?
2024-2-20
DJI Tony
utkin Posted at 2-20 06:16
Hi. Yes, that is correct. Have a great day.
2024-2-24
RayNY
Yes, not sure why I need any noise reduction when I'm at 50 ISO.  That's why I think the pocket 2 has more detail.  The 2 didn't have this feature/problem.
2024-2-24
