GTHero
Flight distance : 1832372 ft
Gyroflow is a piece of free software that stabilises your video using gyroscope and accelerometer data that is embedded in the video. Apparently, Gyroflow does a better job than the two onboard stabilisation options available for Avata users. Basically, it smooths out all the jolts and rolls that the drone's two-axis gimbal is unable to deal with. With Gyroflow you can retain horizon-tilt or output with a levelised horizon. It's easy to use, but you should probably view one of the many online tutorials before you start.
Note that for the Avata to record the data used by Gyroflow, in Settings you need to set Camera FOV to 'Wide' and EIS to 'Off'.
Download from here:
https://gyroflow.xyz/ |
