M30T IR problem
198 3 2-12 11:02
Cambria EMA
My IR is not allowing me to pick the white hot or the black hot palette from the drop down menu. The other IR palettes work. I have tried to re-pair the controler and drone with no change. Any help would be appreciated.
2-12 11:02
DJI Thor
Flight distance : 13602 ft
Hi Cambria EMA, thank you for reaching out. Please turn off the automatic isotherm to see if it helps.
If the isotherm is turned on, black heat and white heat will both be ironbow.
2-13 00:15
Cambria EMA
DJI Thor Posted at 2-13 00:15
[view_image]
Thank you. Working now thanks again
2-14 06:26
DJI Wanda
Cambria EMA Posted at 2-14 06:26
It's our pleasure. Should you have any further inquiries, please feel free to contact us.
2-14 20:06
