Osmo Pocket 3 Magnetic ND Filters Set Problem
2960 8 2024-2-16
utkin
Flight distance : 237733 ft
Singapore
Just received Osmo Pocket 3 Magnetic ND Filters Set and mounted one filter on my Pocket 3. Immediately realized that with the filter mounted on the head, it cannot park properly when the device is switched off.
when filter is not mounted then the head parks correctly:
@DJI Support, what am I doing wrong?
2024-2-16
KlimaPic
Flight distance : 360115 ft
That is a wanted behavior. When a filter is applied, the Pocket is not going into to park mode fully.
Not a bug, its a feature.
2024-2-16
smbishop
Flight distance : 2479334 ft
Depending on the filter thickness, the gimbal will automatically turn and face the camera outward after it tries to close.  However, some of the thinner filters get stuck this way.  At least, this is my experience.
2024-2-16
utkin
Singapore
But this is the DJI original filter! And parking is to protect the lens. So, it is epic failure rather than a feature.
2024-2-16
DaveSp
Flight distance : 6562 ft
Yep, this has been covered previously -
https://forum.dji.com/thread-300685-1-1.html
2024-2-16
DJI Paladin
Flight distance : 318 ft
Hello there. Thank you for reaching out. When in Storage mode, the gimbal camera rotates in various directions, with and without the wide-angle lens. When the Osmo Pocket 3 is turned off and in storage mode, the camera rotates inward automatically. However, with the wide-angle lens installed, the wide-angle lens will touch the axis arm when the camera rotates inward, causing the camera to revolve in the opposite direction, facing the same direction as the touchscreen. In this instance, place the gimbal camera in the protective case. This also applied to both the black mist filter and the ND filter. Hope this helps.
2024-2-16
djiuser_lkSWSpbnLwyr
Same problem with the original DJI filters. This did not happen with Pocket 2. It detected that it had a filter installed and turned in the opposite direction. Will it be implemented in next firmware?
2024-3-15
djiuser_3jGLuCmSoh2p
Okay,
I will be a bit more direct to you DJI !
You gave us a nice updates,  no doubt about that.
You also fixed your biggest mistake = the heat problem with P3 here in EU !
But I am asking directly,  is there a chance to create an update who can allow us to use third party ND filters without removing them when the camera is off ???
2024-5-8
RayNY
I use ones that are thin enough and can close all the way.
2024-5-8
