Gain setting for TX on bluetooth mode ?
2676 10 2024-2-18
forcebio
Hi,
My ride trip yeasterday was a perfect testing for my new DJI Mic 2.
Recording setup was :
- Insta360 X3
- DJI Mic 2 #1 connected via Bluetooth to the Insta360 - On my bike jersey
- DJI Mic 2 #2 used for internal recording - On front of me, clipped on a bicycle bag
The audio for the #1 (bluetooth one) is many times "saturated".
The audio for the #2 (internal) is much better, no clipping.
Is it possible to avoid this clipping on bluetooth ? In the user manual it's indicated that gain setting is for RX/TX and internal recording, but for bluetooth ? Possible ?
Is it possible to be connected on bluetooth AND in the same time recording internal (or with a safe track -6dB) ?
If I can solve that in order to test in real condition on my next bike ride...
Thanks for your help, regards !
2024-2-18
BaynhamPhoto
Flight distance : 491814 ft
You would need to reduce mic gain via your Insta360, the Osmo Action 4 as an example has an adjustable gain of -12 to +12 the Insta 360 may or may not have similar or low, med, high refer to your Insta user guide.
2024-2-18
fans965f61bf
Hi,
Thanks for your answer.
If I modify the gain in the Insta360 X3 (which have this option), is the change affect only Bluetooth connection or il will be applied for connection with the DJI receiver too ?
I known me, I will forgot to change that if i swap from bluetooth connection to cabled connection...
Thanks,
Regards
2024-2-18
DJI Gamora
Hi, there. Thank you for reaching out. Please allow us to check this query with our relevant team for further confirmation.
2024-2-20
forcebio
Hi, no problem.
Thanks
2024-2-20
DJI Gamora
forcebio Posted at 2-20 02:21
Hi, no problem.
Thanks
We highly appreciate your understanding. We will keep you posted as soon as possible.
2024-2-22
DJI Gamora
Hi, no problem.
Thanks
Hi, there. Thank you for your patience. Please know that I've sent you a direct message regarding the update on this query. Kindly feel free to respond if you have further queries.
2024-2-23
forcebio
Hi,
Thanks, seen !
Regards.
2024-2-23
DJI Gamora
forcebio Posted at 2-23 04:36
Hi,
Thanks, seen !
Regards.
Happy to help! Cheers!
2024-2-24
djiuser_PH1r1nYrsPYZ
Flight distance : 154639 ft
The topic is not new, I have exactly the same Problem and cant find any solution according to that.
Maybe the kind DJI support can help me aswell.
2024-6-18
Anonymous1
Flight distance : 602303 ft
Jamaica
fans965f61bf Posted at 2-18 13:20
Hi,
The GAIN adjustment feature only affects what is recorded to the Insta360.    What is recorded internally on the Mic2 remains the same (especially when recording in 32-bit float).
I recently bought an Insta360 Ace Pro, and this has been my experience too.
2024-8-15
