DJI Mic TX 1 Low Input
248 1 2-18 15:06
mdmngz
Not sure how to fix this.  I've looked everywhere for a solution.  I purchased these a couple months ago and never really had to use both transmiters at once.  Really just only used one.  To my luck, i've been using the only one that seems to work.  A couple weeks ago i tried to use both for a shoot and quickly ralized that one of them was emiting noise/static.  When i went to go check the recording it was in fact not coming through all the way.  here seems to be something faulty with my tx1 in the fact that it is not reciving the audio as it should and it seems to be muffled in some way.  I've tried taking off the low pass, increasing gain, updating it, relinking it, etc.  No luck
Has anyone else had something like this happen to them?
I've attached an audio test at 10+ gain to have you listen to this
Muffled Audio
2-18 15:06
DJI Wanda
Hi there, sorry to hear that. Would you mind sending us the audio through DM? We will further check it for you. Thank you.
2-18 23:27
