DJI Gamora
Heincken Posted at 3-29 12:28
Hello DJI Gamora
Is it the case that the calibration should fix itself?
My mini4 ran out of battery and hovered over a tree about 5m above the ground and wouldn't move when it was in RTH mode and when it ran out of power it fell down the branches in the snow. No visible damage, but for the same Sensor error and that Auto Calibration is in progress, but nothing happens after 5 minutes
Hi, Heincken. Yes, vision sensor error should be fixed by calibration. If it did not, then I'm afraid that you may consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support. |
