Can I use a 300w Charger on my Air 3?
548 6 2-22 07:02
donbyler
Flight distance : 696594 ft
Hey all,Would anyone know if it would hurt my batteries to charge with a 300w charger? I see a lot of people use 100w, and it would be really nice to be able to use a 300w but I dont want to ruin the batteries. I have the charging bank that comes with the fly more kit.
Thanks, Donavon
2-22 07:02
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The aircraft supports a maximum charging power of 65W. If the charging power is higher than 65W (If you are using 300W), it will also reduce its power to 65W during charging. Also, the Charging Hub can support a maximum charging power of 100W therefore, if you are using a 300W PD charger for charging, it will also reduced to 100W. Hope this helps.
2-22 23:13
donbyler
Thanks, thats what I was looking for. So essentially what you're saying is it wont hurt to use a 300w charger but theres no benefit to one over a 100w?
2-23 05:29
MisterFrag
Flight distance : 603143 ft
Yes, it's safe to use a 300W charger.
2-24 11:16
TotalNewb
Basically as said above most chargers will adapt to the power needed, just try to get the best quality you can afford, Anker and Ugreen are my preferred power plugs, GAN compatible.
2-27 10:38
donbyler
Ok thanks guys!
2-27 11:36
Geo_Drone
Flight distance : 2676129 ft
Romania
You can use a 10.000 Watts supply power, the charger will only deliver the max supported by battery.
Important is to be extremely stable, as Li-Ion is highly sensitive to voltage variations in charging process.
2-28 01:34
