Stripped screws
269 8 2-22 10:57
Zachari mckay
Flight distance : 249101 ft
Hey guys I was replacing my props on the Dji mini 3 pro, little did I know to screw was stuck and I was stripping it!. Please help me someone I don't know how to get the screw out!!
(There is absolutely no traction on the screw)
2-22 10:57
Serg SSA
Flight distance : 6406329 ft
Russia
try laying a thin elastic band
2-22 11:37
Zachari mckay
Hi
I did try that but the rubber band is to big to fit in the hole because it is such a small screw, and the screw driver puts holes in the rubber band cause it is so sharp
Would putting gorilla glue on the screw and inserting the screw driver and waiting for it to dry  work?
2-22 11:46
Serg SSA
Russia
Zachari mckay Posted at 2-22 11:46
Hi
Yes, you can drop a drop of quick glue and immediately glue the screwdriver, But it's dangerous, you can't glue the propeller to the propeller
2-22 11:48
Sean-bumble-bee
Flight distance : 15997 ft
Have you rounded out the cross slot?
If so and all else fails, tape over ALL the openings into the motor, to keep bits out of the motor, and file or cut away the top of the propellers hub to expose the head of the screw then grip the head of the screw with pliers and undo it.
2-22 12:29
Zachari mckay
Thank you I will look into
Have you tried this before? (Did it work?)
2-22 12:53
Zachari mckay
Yes I have rounded out the cross slot there is absolutely no friction on the screw
2-22 12:54
Zachari mckay
Guys
I talked to someone from the Dji store they said I should send the drone to them and I am worried that will take a long time because I live so fare away
Should I just remove the screw myself?
2-22 19:40
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. To avoid any further damage to the unit. We highly recommend to send it in for us to check it further. You may contact again our team at https://www.dji.com/support to see the best option for you to send the unit. We appreciate your understanding.
2-22 22:33
