DJI Support
Flight distance : 2408 ft
China
Overview
- Release Date: 2024.12.06
- Zenmuse L2 Firmware: v04.00.1001
- Firmware Upgrade Method: microSD card / Update All in App
- Compatible Firmware and Software Required:
- M350 RTK Aircraft: v10.01.0805
- M300 RTK Aircraft: v60.01.0806
- DJI RC Plus Remote Controller: v05.02.1301
- DJI Pilot 2 App: v10.1.8.17
What’s Fixed
- Fixed the issue of a significant difference between the actual image quantity and the estimated value during the LiDAR Mapping flight task with RGB Coloring enabled.
- Fixed the issue where occasional malfunctions occurred after entering and exiting Playback multiple times within a short period.
- Fixed the issue of video transmission freezing in visible light and point cloud live view.
Notes:
- Make sure that the aircraft firmware, the remote controller firmware, the L2 firmware, and the DJI Pilot 2 App are all updated to the latest version.
Overview
- Release Date: 2024.11.07
- Zenmuse L2 Firmware: V04.00.07.01
- M350 RTK Aircraft: V10.01.08.05
- M300 RTK Aircraft: V60.01.08.06
- DJI RC Plus Remote Controller: V05.02.13.01
- DJI Pilot 2 App: V10.1.8.16
What’s Fixed
- Added support for Power Line Follow mode when using with M300 RTK and DJI RC Plus remote controller.
- Added Efficiency mode when enabling IMU Calibration in LiDAR Mapping task. The number of calibration flights will be reduced during the task in Efficiency mode.
- The RGB camera will not capture photos during the task if RGB Coloring is disabled when creating the LiDAR Mapping flight task.
- Optimized Power Line Follow function:
- When the aircraft hovers above the branch point, it is supported to pause the task and resume it after manually controlling the aircraft to fly through the branch point. The point cloud recording will not be interrupted.
- When the aircraft hovers above the branch point, it is supported to control the gimbal using the dial on the remote controller.
- Added Mark Branch Point feature. PinPoint will be automatically added at the branch point
Notes:
- Make sure that aircraft firmware, the remote controller firmware, the L2 firmware, and the DJI Pilot 2 App are all updated to the latest version.
Overview
- Release Date: 2024.07.18
- Zenmuse L2 Firmware: V03.00.00.05
- M350 RTK Aircraft: V10.01.00.09
- M300 RTK Aircraft: V60.01.00.03
- DJI RC Plus Remote Controller: V05.02.11.06
- DJI Pilot 2 App: V10.1.0.30
What’s Fixed
- Added support for Power Line Follow mode when using with M350 RTK, which is suitable for power line point cloud collection.
- Added RTB data in task quality report for LiDAR Mapping flight route tasks.
- Optimized LiDAR Mapping in Oblique tasks. It is supported to generate better 3D models when using with DJI Terra.
- Optimized Point Cloud liveview display and reduced point cloud drafting during flight.
- Fixed issue: When point cloud recording has ended abnormally, the new task folder only contained JPG files while LDR and IMU files were in the previous task folder.
- Optimized synchronization strategy of radar time and fixed occasional point cloud position issue in some scenarios.
Notes:
Overview:
- Release Date:2024.04.28
- Zenmuse L2 Firmware:v02.00.0002
- Firmware Upgrade Method:microSD card / Update All in App
- M350 RTK Aircraft:v10.00.06.02
- M300 RTK Aircraft:v60.00.01.07
- DJI RC Plus Remote Controller:v03.02.09.08
- DJI Pilot 2 App:v10.0.6.12
What’s Fixed
- Fixed an occasional issue: Camera fan error prompts incorrectly.
Notes:
Overview:
- Release Date: 2024.02.22
- Zenmuse L2 Firmware: v02.00.0001
- M350 RTK Aircraft: v09.01.01.02
- M300 RTK Aircraft: v59.01.00.01
- DJI RC Plus Remote Controller: v03.02.09.07
- DJI Pilot 2 App: v9.1.0.21
What’s Fixed
- Added support for H.265 as the default video encoding format. Users can switch the default format in Camera Settings.
- The interval of IMU Calibration is extended to 200 seconds during a flight route task.
- Optimized Point Cloud LiveView display and reduced point cloud drifting when the aircraft is hovering.
- Optimized the storage format of point cloud files to reduce the point cloud recording file size in some scenarios.
- Fixed issue: When the gimbal connector was connected to the left USB-C port on the aircraft (when facing the aircraft), the app displayed that L2 was Payload 1.
- Fixed issue: When RGB Coloring was enabled and the recording mode was switched to point cloud, users were unable to stop taking photos and start a point cloud recording in the app after pressing the shutter button on the remote controller.
- Fixed issue: After failing to obtain the task quality report, the app showed that the report file cannot be found while the file existed in the microSD card.
Notes:
- The point cloud data captured by the L2 with updated firmware requires DJI Terra v4.0.0 or later version to calculate.
- The firmware cannot be downgraded to v01.00.0002 or lower after updating to this version.
