DJI Lightbrigde 2 Release Announcement
2807 17 2015-9-11
DJI-Autumn
Lightbridge 2
DJI Lightbridge 2 breaks technical limits to allow you to travel further and see more clearly. The integrated controller and intelligent algorithms set a new standard for wireless HD image transmission by lowering latency and increasing maximum range and reliability.
Professional HD Broadcasting
LB2.jpg Broadcast everything live - from global news events to sports to your local concerts and gatherings, all directly tolarge-screen displays, multi-million YouTube audiences and standard TV channels.
The Lightbridge 2 has been designed from the ground up to meet the requirements of professional broadcasting at high frame rates and HD clarity. USB, mini-HDMI and 3G-SDI ports support video output at up to 1080p/60fps or broadcast standard output of 720p/59.94fps and 1080i/50fps.
Responsive Navigation, Real-time Video
With a new, powerful hardware encoder and advanced algorithms, total latency has been significantly reduced to as low as50ms.* So fly FPV, see what your camera sees, and capture footage as never before.
Aircraft and camera control signals are also transmitted over Lightbridge 2 at lightning fast speeds, giving you smooth, responsive navigation as you fly or direct your camera.
*Latency does not include camera latency. Effective latency is dependenton local conditions and interference.
Incredible Range
Lightbridge 2 wirelessly transmits HD video at a range of up to 1.2 miles (2 km).*
All this to ensure that you will be able to explore distant locations and capture any perspective, always receiving a crystal clear image of your camera’s sight.
*Maximum range in open areas under optimal conditions free ofinterference.
Integrated Design
Start broadcasting within seconds. The Lightbridge 2 greatly reduces the number of parts you must carry, mount, and set up. With the receiver fully integrated into a new remote controller, simply connect your display equipment, power your system on, and you are ready to go.
The included remote provides easy access tovital functions. It has dedicated hardware controls for photo and video capture, gimbal pitch control, sensitive flight control sticks and dedicated Return To Home and customizable buttons.* Additionally, an internal,rechargeable 6,000mAh battery lets you fly longer and makes charging easy andquick.
*Camera control functionality is dependent on the paired camera. Custombutton functionality is dependent on the Flight Controller.
Intelligent,Dynamic Transmission
Lightbridge 2 is intelligent. It automatically adapts in real time to keep latency low while maintaining a strong signal. For uninterrupted transmission, a high-speed processor chooses the bestchannel and bandwidth based on current distance and electro magnetic environment.
When using the DJI GO app, you can chooseto maximize video quality or focus on lower latency, and manually change toyour desired transmission channel.
Team Up
Transmit the same live HD view wirelessly to several devices by connecting multiple remote controllers in Master-Slave mode. Increase efficiency by working together to accomplish complex imaging and broadcasting tasks. Lightbridge 2 supports up to one Master and three Slave devices at the same time, so the pilot, gimbal operator, director, and broadcast team can all receive the video signal and monitor the shooting process from different places.
Absolute Control on Your Device
Use the powerful DJI GO app to control your camera, access intelligent navigation settings, and receive a live HD view of what the camera sees, on your paired mobile device. Flight information including current status, full telemetry, location, heading, and more is displayed and updated live, making every flight safe and convenient.
Ready to Go
Lightbridge 2 supports a range of professional-level DJI products. This means that you can build your custom system out of parts that work perfectly together, because they were designed to. If you have an existing system based on the previous version of Lightbridge, or are currently using a analog or WiFi-based video downlink, you can easily upgrade to the Lightbridge 2.
Stream to Anything
Output full HD video to almost any type of display – mobile phones and tablets, desktop displays and TVs can all receive live video output. You can even output video to several devices simultaneously through a combination of ports, either USB and 3G-SDI, or USB and mini-HDMI.
Dual Video Stream
Lightbridge 2 can transmit video from two cameras simultaneously: the main camera used to capture video and photographs,and a second camera showing the First Person View (FPV).
Output a Picture-In-Picture view via mini-HDMI or 3G-SDI to a TV or other external display, where the FPV is layered with the main camera view. The views and controls are completely independent so that the gimbal control will not affect the pilot view or the aircraft’s navigation, and vice versa.
Learn more
2015-9-11
SURESHBAABU
India
Fantastic update of Lightbridge 2,
I have two questions,
1. Can I take picture & video simultaneously like Inspire or phantome3 on GH4 - S900 - means can I able overdrive the settings while the S900 in air?
2. Is it possible to change the aperture & focus when the S900 in air,
2015-9-11
uhayat
Flight distance : 191421 ft
Pakistan
Ditto questions, awaiting an answer DJI-Autumn.
2015-9-11
Paulo Paulino
Flight distance : 2774265 ft
Portugal
1) If Lightbrigde 2 use DJI GO app, we will have Intelligent Flight Modes available like p3 and Inspire?
2) Why on compatible dji gimbals never show Z15-BMPCC if this gimbal is also HD?
2015-9-11
Paulo Paulino
Portugal
I have other question.
We will have full telemetry integrated in Dji Go app about batteries cells voltage in Lightbridge 2?
(There are a lot of hardware doing that on the market like cheap QUANUM telemetry, I hope this is implemented in new LB2).
Don´t forget to add on Dji website Lightbridge 2, product Compatible DJI product list / DJI gimbal system, (Z15-BMPCC).
Thanks.
2015-9-12
RDTeam54
R&D Team
SURESHBAABU Posted at 2015-9-12 00:20
1: no, the camera can only be controller like before, such like a switch with futaba, and only taking photo can be triggered. taking video can not.
2: no, mainly because the camera is not DJI camera, we don't have the interface to control it.
2015-9-17
RDTeam54
R&D Team
Paulo Paulino Posted at 2015-9-12 02:49
1) If Lightbrigde 2 use DJI GO app, we will have Intelligent Flight Modes available like p3 and Insp ...
1:actually it depends on the FC, if you are using A2, there is no that much function for it.
2:yes, the Z15-BMPCC is supported. and all of the HD gimbal needs upgrade to support LB2.
2015-9-17
RDTeam54
R&D Team
Paulo Paulino Posted at 2015-9-13 02:31
We will have full telemetry integrated in Dji Go app about batteries cells v ...
no, there is no cells voltage on LB2
2015-9-17
Arrow1969
Flight distance : 400577 ft
When will the spare transmitters be available to use as Slave and how much??
2015-9-19
hummingbird.uav
Flight distance : 8330174 ft
Could an exiting Phantom 3 or Inspire 1 transmitter be used as a slave with the new LB2?
2015-9-28
hummingbird.uav
Can LB2 be used with a NAZA-M v2 FC or just the A2 & Wookong ?
2015-9-28
rmoura
Flight distance : 4017802 ft
Brazil
Is it possible to link a Lightbridge air system and a Inspire 1 RC for S900 with A2?
2015-9-30
nsvr66
Ban Posts
Flight distance : 84347 ft
2015-9-30
g.coduri
Hallo does the new lightbridge 2 support zenmuse z15 nex 5? thanks in advance
2015-10-6
TDL
Switzerland
We being working with DJI gear for years but only not happy with Inspire 1.
Was considering another combination like Evo800, WKM, Lightbridge2 with Zenmuse or other available gimbal.
Main question is: How does LB2 ¨communicate¨with the camera, and how can i trigger the DSLR? (without using time interval, as u know each trigger count )
Thanks
2015-10-11
Daedalus
Flight distance : 557552 ft
Cyprus
Looking forward...!
2015-10-14
adam
Where is Lightbridge 2 non-joystick base station?
Will a non-joystick Lightbridge 2 base-station be offered?  There aren't even enough functions on the LB2 radio for a single operartor to even control the standard DJI A2 & Wookong options....for example: IOC, switch iOSD cameras, gimbal yaw control (no dedicated dial), Zenmuse Mode control, Gear up/down, adjust gains, Dropsafe deployment...what about other switches that many of us need like: dual rates, lights off/on, 3rd party gimbal joystick on/off etc.  And moving these options to the phone app means trying to find icons on your phone while flying, in my case with goggles on.  Right now I know by feel where each switch and dial is and what it does but how can I do this if these options are icons on a phone display ...THIS RADIO IS A TOY leaving your most invested customers (many thousands of dollars) with no options, UGH!!!
2015-10-15
adam
In the DJI LB2 video there is a scene where a secondary video receiver is used...when will this be available and can it replace the joystick transmitter for video downlink?
2015-10-16
