Dji mini4 pro error fly with caution.
484 8 2-25 10:00
Dimis Kat filmnavigate
Greece
Hello after tha aicraft update i lost the sensors.   code: 180059 Aircraft not in flight. Vision systems and obstacle avoidance disabled . and the problem is and when is at tdoes not eneble the sensor. and the gps error is alltime red after update to 7-9 satelite GPS Signal 30008
erros
erros
errors
errors
2-25 10:00
JeremyB31
Flight distance : 1364560 ft
Do the errors remain after you are flying?
2-25 13:32
Manitobahunter
What aircraft update was it?
2-25 18:59
DJI Gamora
Hi, Dimis Kat filmnavigate. Thank you for reaching out. May we ask about the firmware version you just updated? Also, was the aircraft on the ground when you received the error? Was there any error while in flight as well?
2-25 19:56
Greece
JeremyB31 Posted at 2-25 13:32
yes it is remain
2-25 22:02
Greece
DJI Gamora Posted at 2-25 19:56
Thanks fo your reply the last firmware was at 75% i did complete. and the same. after reset all the problem fixed.
2-25 22:16
DJI Gamora
Dimis Kat filmnavigate Posted at 2-25 22:16
Thank you for the reply, Dimis Kat filmnavigate. Just to confirm, the issue has been resolved after you completed the update?
2-27 05:04
Greece
DJI Gamora Posted at 2-27 05:04
confirm that
2-27 06:00
DJI Gamora
Thank you for confirming, Dimis Kat filmnavigate. Glad that the issue has been fixed after completing the update. Should you need further assistance, please don't hesitate to reach us again. Have a safe flight always!
2-28 07:28
