Low battery level and RTH
1057 10 2-26 02:18
exter
Flight distance : 4085 ft
Fly indoors and have set RTH to Hover for signal loss, but what happens when the battery level is too low. Don't want RTH to activate.
2-26 02:18
JJB*
Flight distance : 13365584 ft
Hi,
Indoor flying without GPS reception means no HP set and now RTH ofcourse.
Indoor flying with GPS....depends if HP is set (white GPS icon top right FlyApp), and when HP is set distance drone to HP at low batt gets important. (read manual)
BTW best to fly always with a full battery and land at 30%. :-)
cheers
JJB
2-26 02:29
DJI Tony
Hi there. You can cancel RTH by pressing the RTH button on the remote controller. However, please take caution. If RTH is canceled following a low battery warning, the Intelligent Flight Battery may not have enough power for the aircraft to land safely. As a result, you may crash or lose your aircraft. Have a nice day.
2-26 02:33
JJB*
DJI Tony Posted at 2-26 02:33
Hi Tony,
If i cancel a low battery RTH than the critical low battery landing comes next.
This will land the craft safely....( if not 'cancelled' by the pilot by UP stick all the time...)
cheers
JJB
2-26 03:09
DJI Tony
JJB* Posted at 2-26 03:09
Hi Tony,
Hi. Yes. Thank you very much. That made it clearer.
Have a great day ahead.
2-26 03:22
Sean-bumble-bee
Flight distance : 15997 ft
Previously, just for curiosity's sake, I have pressed the RTH button whilst indoors with 0, zero, GPS, ...... nothing happens ... as was expected. I might have got a message saying "0 GPS, RTH unavailable" or words to that effect.
Additionally, depending on the floor area, my minis ( 1 & 2 ) are inclined to reject the landing site even if the controller is disconnected by switching it off, that leaves the drone the drone hovering.
This rejection has in the past meant that the drone will, from memory, not auto land until the battery hit 0, zero, percent.
2-26 08:30
exter
Obviously it is not possible to switch off rth. The conclusionis to interrupt rth push the break button. That is what i already sometimes did outdoors if I want correct the landing. Thanks for all the reactions.
2-26 09:15
Labroides
Flight distance : 9991457 ft
exter Posted at 2-26 09:15
It's not hard to monitor your battery level and stop flyingbefore low battery RTH wants to activate.
2-26 14:11
DJI Tony
You are most welcome. Let me forward your feedback to the development team for consideration. Thank you for your valued support.
2-27 01:58
exter
Labroides Posted at 2-26 14:11
That can differ a lot because it depends of the software calculation based on position distance and rth setting.
2-27 03:43
JJB*
exter Posted at 2-27 03:43
you forgot something...depends also the height drone is flying   ;-)
But all this not when flying indoors, to your question asked in post #1.
cheers
JJB
2-27 04:04
