film an area at different times with the drone? same route.
497 2 2-26 04:06
ande
Flight distance : 264308 ft
Sweden
How do I if I want to film an area at different times with the drone?
Want the drone to fly the same route every time.
Is there an app for that?
Have a dji phantom 4 pro and the mini 3 pro.
Will do it with phantom 4 pro
is an area where they are going to build a dam
Tips?
Maybe there is a god guide on youtube?
can't find any
2-26 04:06
DJI Gamora
Hi, ande. Thank you for reaching out. We recommend using the Waypoints function. Waypoints record a flight path, then the aircraft will fly along the same path repeatedly while you control the camera and orientation. The flight path can be saved and re-applied in the future. To perform this, you will need to download the DJI GO 4 app. You may download the DJI GO 4 app for the Phantom 4 Pro on this link: https://www.dji.com/downloads/products/phantom-4-pro
For video tutorials, you may search Phantom 4 Pro Waypoint on YouTube. Hope this helps.
2-26 23:37
WInged Eye
Flight distance : 1077618 ft
Litchi. I have done exactly as you describe showing the 4 seasons passing. I find litchi more robust and easier to use than waypoints. You can create a route on a desktop/laptop and save it.
I don't know if using Litchi may affect RID. I have a P4Pv2.o that software upgraded to RID so I have not yet tested with Litchi to confirm that it works.
2-28 08:55
